Davek77
Sep 15, 2025Aspirant
Help save my marriage š¤£
Heys guys Sky Q Sky hub 4.2 orbi rbr850 with 2 satellites. so Iāve tried to get this working myself but the tech terminology has me frazzled. As sky doesnāt allow bridge mode I put m...
Davek77
Is this what you mean?
Sep 15, 2025Guru - Experienced User
You could enable DMZ server for the RBR in Router mode if you want to try that. I would. See the IP address on the RBRs web page under Advanced Tab/Internet Section for the IP address. Input this IP address into the modems DMZ Server there and check mark it as enable then select Apply.
I would remove the check marks for Respong to Ping on Internet WAN port and WAN port IPv6. This means nefarious scans could see your modem. A security risk if enabled.
If you have a friend, family member or nieighbor what has some tech experience, might ask for additional help as well.
- Davek77Sep 15, 2025Aspirant
Unfortunately Iām our tech experience but I can follow direction or can screenshot the options available for you to help š
thanks so much as Iām at my whits end.
had Vodafone but switched to sky 1gb last wk but disaster ever since.
Iāve followed YouTube and web pages tutorials and I thought I had it sorted.
i can put up screenshots if that helps?
I took loads š«£š¤£
both sky hub and orbi router
thanks again
- FURRYe38Sep 15, 2025Guru - Experienced User
Had the Orbi system worked with the prior Vodafone system or is all this new along with the SkyQ?
