Davek77
Sep 15, 2025Aspirant
Help save my marriage 🤣
Heys guys Sky Q Sky hub 4.2 orbi rbr850 with 2 satellites. so I’ve tried to get this working myself but the tech terminology has me frazzled. As sky doesn’t allow bridge mode I put m...
Davek77
Sep 16, 2025Aspirant
Hi guys
i tried the DMZ option and put Orbi in router mode.
i see I have that option 61 on Orbi that sky needs
ill attach he’d a few pics of setup of sky router and Orbi router.
i may have made mistakes but it working.
if ye would check to see did I do anything wrong that would be greatly appreciated
thanks
- FURRYe38Sep 16, 2025Guru - Experienced User
Ask the ISP if the Option61 is needed if the Orbi router is behind the ISP Router. I don't believe it maybe needed since the ISP router maybe handling this already, however never hurts to configure it as see. The ISP will have this info. If it's working good, then you might leave it for a while and run some tests and let the family check it out and give you feedback.
