tperezb
Sep 07, 2025Aspirant
How can I add a RBS50 satellite to my new RBE773 router?
I just purchased a new RBE773 system to upgrade my old RBS50. But I wanted to add the 2 satellites to the RBE773 Is it possible to do so? How many satellites can I add to a RBE773 router?
CrimpOn
Sep 07, 2025Guru - Experienced User
Sorry. No. Netgear Orbi WiFi7 are not compatible with earlier WiFi5 and WiFi6 systems:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Netgear recommends a maximu of four satellites on WiFi7 systems:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
Obviously that depends on the number of devices and type of usage.
