Crasje
Mar 13, 2025Tutor
How to set up Orbi 870 (873) as an access point?
Hello, I see in the instructions on how to set it up as normal (with the app) and I also found a page where it explains how to configue the router as an access point. What I would like to know,...
- Mar 13, 2025
The attached PDF for AP mode is the one.
Yes, if it's working then keep it. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡Please mark your thread as solved so others will know.
KevinLiT
Mar 13, 2025NETGEAR Moderator
Hello Crasje ,
Welcome to the NETGEAR Community!
First, you set up your Orbi system normally.
Then, you select access point mode (located under the advanced tab) if this is your desired configuration.
Best,
Kevin
Community Team
- CrasjeMar 13, 2025Tutor
Will do, thank you for your input!!
