jeanluca
Apr 06, 2025Follower
How to verify Wifi 7 from Orbi RBE971
I have a Netgear Orbi RBE973SB (router + 2 satellites), but I'm wondering how exactly Wi-Fi 7 works. From what I understand, it should use the 6 GHz band, but in my router’s configuration I only see ...
- Apr 06, 2025
What WiFi7 and MLO active looks like on my 970 RBR with Intel BE200 series cards install in two PCs:
Apr 06, 2025Guru - Experienced User
You'd need something that supports 320hz wide channels to see it. You might also need a different app. That same app on my phone with wifi 7 only shows 20hz wide channels in 6ghz but if I pull up a different one (acrylic) on my PC and laptop with wifi 7, it shows 320hz wide. And my link speed is indicative of that.
- TOPS119Apr 06, 2025Virtuoso
It doesn't show me wifi 7 either and I have a s25 ultra which is the latest model that shows wifi 7 wifi 6 comes up
