jeanluca
Apr 06, 2025Follower
How to verify Wifi 7 from Orbi RBE971
I have a Netgear Orbi RBE973SB (router + 2 satellites), but I'm wondering how exactly Wi-Fi 7 works. From what I understand, it should use the 6 GHz band, but in my router’s configuration I only see ...
- Apr 06, 2025
What WiFi7 and MLO active looks like on my 970 RBR with Intel BE200 series cards install in two PCs:
TOPS119
Apr 06, 2025Virtuoso
Funny enough the 340 is depended on what region you live in they dont seem to allow ppl outside of the usa and Canada to select the 340 which is weird in my opinion
CrimpOn
Apr 06, 2025Guru - Experienced User
There are significant differences in regulation of radio frequencies around the world. Wikipedia has a nice summary:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
- TOPS119Apr 06, 2025Virtuoso
Should we be seeing 7GHz here?
- FURRYe38Apr 06, 2025Guru - Experienced User
No.
Any WiFi7 or MLO will be indicated on the connecting device and shown on the RBR connected device web page. When 5+6Ghz is seen here, this indicates WiFi7 and MLO are active and being supported.
If you notice right here my Laptop says wifi 6, Which is a 6e device fine but my Phone Google pixel 9 says wifi 5 which is a wifi 7 device isn't that crazy
- donawaltApr 06, 2025Hero - Experienced User
No - this image is complete. See my post above, there is no 7 GHz channel, WiFi 7 uses 5GHz and 6GHz in Netgear's case.
The 970 shows WiFi 7 and in effect MLO on the router admin web page, As you may know, MLO stands for Multi-Link Operation, and it’s one of the key new features in Wi-Fi 7 (IEEE 802.11be). MLO works across the 5 and 6GHz frequency bands (for Netgear - the spec supports using 2.4 band too), not necessarily using the older Wi-Fi 5 protocol. All the links are Wi-Fi 7 protocol (or at least 6E/7), just operating across different spectrum bands.
So is there a 7GHz frequency band? No! There isn’t a new frequency band unique to Wi-Fi 7. Instead, Wi-Fi 7 operates across existing frequency bands, just like Wi-Fi 6 and 6E. But the magic is in how it uses them.
So go to the Attached Devices list after logging in at 192.168.1.1. There is a 'connection type' column, which will be 2.4GHx, 5, 6, or '5GHz+6GHz' (see image below). This is WiFi 7, using MLO.
While you can see MLO being used, which is a WiFi 7 capability, indicating a device is using WiFi 7, you cannot see 320MHz channel width or 4096-QAM anywhere I know of - even though Netgear advertises it's supported on the 970 Orbi series:
https://www.netgear.com/hub/wifi/mesh/orbi-970-wifi-7/
Here is the Attached Device Connection type for my iPhone 16 Pro, which uses WiFi 7:
