jeanluca
Apr 06, 2025Follower
How to verify Wifi 7 from Orbi RBE971
I have a Netgear Orbi RBE973SB (router + 2 satellites), but I'm wondering how exactly Wi-Fi 7 works. From what I understand, it should use the 6 GHz band, but in my router’s configuration I only see ...
- Apr 06, 2025
What WiFi7 and MLO active looks like on my 970 RBR with Intel BE200 series cards install in two PCs:
CrimpOn
Apr 06, 2025Guru - Experienced User
There are significant differences in regulation of radio frequencies around the world. Wikipedia has a nice summary:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
TOPS119
Apr 06, 2025Virtuoso
Should we be seeing 7GHz here?
- FURRYe38Apr 06, 2025Guru - Experienced User
No.
Any WiFi7 or MLO will be indicated on the connecting device and shown on the RBR connected device web page. When 5+6Ghz is seen here, this indicates WiFi7 and MLO are active and being supported.
- TOPS119Apr 06, 2025Virtuoso
If you notice right here my Laptop says wifi 6, Which is a 6e device fine but my Phone Google pixel 9 says wifi 5 which is a wifi 7 device isn't that crazy
- donawaltApr 06, 2025Hero - Experienced User
This picture shows a Shield TV Pro, that's a media player. Are you sure you are looking at the right setting?
I don't have a Google phone, you can see what my iPhone 16 looks like in the device report in the post above. The iPhone does have a setting to turn on/off WiFi 6 and up, so make sure your Google phone is configured correctly. It should say 5GHz+6Ghz as mine does, if it's running at WiFi 7.
No - this image is complete. See my post above, there is no 7 GHz channel, WiFi 7 uses 5GHz and 6GHz in Netgear's case.
