tbar9
Mar 01, 2026Initiate
HP Printer will not connect to new Orbi 870
I upgraded my network from a Wi-Fi 5 Orbi to an 870. After getting everything back online everything is working except for my HP wireless printer. I've tried normal DHCP and assigned DHCP. I also tr...
CrimpOn
Mar 01, 2026Guru - Experienced User
There are some WiFi devices which are incompatible with the 'mixed' WPA2+WPA3 security scheme. PaulGo is right. It has been proved to connect to the IoT network. "Problem solved."
p.s. If the learning exercise is worth the time and effort, you could contact HP support and ask if this specific model of printer is compatible with the mixed security setup.
