AbbasRaza
Nov 14, 2023Guide
I am currently on IOT network with my pixel 8 pro
Can you tell us when will you guys release the firmware. I am currently on IOT network with my pixel 8 pro.
- Nov 22, 2023
Did you get a beta version from NG that was working? If you had then updated over that, then you might have re-introduced the problem. If you have the beta version from NG, you'll need to apply it back ON again to the RBR. You'll also need to disable Auto Update as well on the RBR first.
Straq
Nov 14, 2023NETGEAR Expert
Hi there,
Engineering team here. It will be about a few weeks before FW release. I will be messaging directly if you will like to receive FW earlier.
