AbbasRaza
Nov 14, 2023Guide
I am currently on IOT network with my pixel 8 pro
Can you tell us when will you guys release the firmware. I am currently on IOT network with my pixel 8 pro.
- Nov 22, 2023
Did you get a beta version from NG that was working? If you had then updated over that, then you might have re-introduced the problem. If you have the beta version from NG, you'll need to apply it back ON again to the RBR. You'll also need to disable Auto Update as well on the RBR first.
Nov 15, 2023Guru - Experienced User
why are you on the IoT network?
It won't connect to the primary network?
what version of android is on the pixel pro 8?
Reason I ask is my Moto Edge+ 2023 only connects to wpa2 and has issues with mixed wpa2/wpa3 on Wifi 7.
Supposed to be an update someint with android 14 that fixes the issue but I have it on both my RBE973s and an Arris G54 (wifi 7)
AbbasRaza
Nov 15, 2023Guide
It's because of the pixel 8 pro. If I connect to the primary SSID the orbi just randomly reboots itself. Every time. It's a known issue and Netgear team is aware of this. Please see above comments from the engineering team. They are trying to fix this issue with a firmware update. For some reason it works perfect on the IoT network. I have it set to 2.4 GHz Wi-Fi only.
- FURRYe38Nov 15, 2023Guru - Experienced User
FYI, another user mentioned putting there Pixel devices in the IoT network and it solved the issue as a work around. Yes, NG is aware of it and does have a fix there testing. I believe you can get the fix from Straq
Please send him a private message and check on this.
- AbbasRazaNov 15, 2023GuideYup he did reach out to me. I just want to make sure if anyone else has used this beta firmware from him and has had no issues. Any info will help before I pull the trigger on the beta firmware
Load it up. RBS first then RBR lastly. After the system has processed the new files, I'd power OFF the system for 30 seconds then back ON. Give about 5-10 minutes for the system to fully come to ready. Disable the IoT network then try your Pixel devices on the main Wifi network you have setup.
Let us know the results.
