AbbasRaza
Nov 14, 2023Guide
I am currently on IOT network with my pixel 8 pro
Can you tell us when will you guys release the firmware. I am currently on IOT network with my pixel 8 pro.
- Nov 22, 2023
Did you get a beta version from NG that was working? If you had then updated over that, then you might have re-introduced the problem. If you have the beta version from NG, you'll need to apply it back ON again to the RBR. You'll also need to disable Auto Update as well on the RBR first.
AbbasRaza
Nov 22, 2023Guide
I saw the update popup when I checked on the orbi app on my phone and I downloaded it. I am now back on my Iot SSID. If I go back on my primary SSID the orbi goes cukku cukku again.
Nov 22, 2023Guru - Experienced User
- AbbasRazaNov 22, 2023GuideOkay I will send a private message to the engineering person and get the firmware again. How do I disable the auto download on RBR
- FURRYe38Nov 22, 2023Guru - Experienced User
Check for a enable and disable Check For FW Updates on the FW Update page on the RBRs WEB Ui.
Did you not keep the intial beta FW file they sent you?
- StraqNov 22, 2023NETGEAR Expert
I have reached out to him. He previous had V9.10.1.3001. V9.10.1.4 does not have fix for Pixel which is reason why he sees issue again.
- nakiriNov 22, 2023Guide
Thanks for confirming that. I had turned off auto updates and will also stay on x.x.x.3001 for the time being -- which is working fine for me.
Is the Pixel 8 Pro hot fix in the next release stream?
- AbbasRazaNov 28, 2023Guide
So far so good. The Router has been working great under this V.10.2.3. with my pixel 8 pro. I have not installed my one satellite since i have updated to this firmware because i noticed whenever any device that is using the quest SSID for some reason when they are connected to the satellite the device shows that it has full connection and everything but there is no internet working for example google chrome, youtube nothing loads. Do you think this new V10.2.3 fixes this guest network issue?
- FURRYe38Nov 28, 2023Guru - Experienced User
IF you didn't update the RBS, lets get that online. Hopefully it will connect so you can update the RBS.
