AbbasRaza
Nov 14, 2023Guide
I am currently on IOT network with my pixel 8 pro
Can you tell us when will you guys release the firmware. I am currently on IOT network with my pixel 8 pro.
- Nov 22, 2023
Did you get a beta version from NG that was working? If you had then updated over that, then you might have re-introduced the problem. If you have the beta version from NG, you'll need to apply it back ON again to the RBR. You'll also need to disable Auto Update as well on the RBR first.
AbbasRaza
Nov 28, 2023Guide
So far so good. The Router has been working great under this V.10.2.3. with my pixel 8 pro. I have not installed my one satellite since i have updated to this firmware because i noticed whenever any device that is using the quest SSID for some reason when they are connected to the satellite the device shows that it has full connection and everything but there is no internet working for example google chrome, youtube nothing loads. Do you think this new V10.2.3 fixes this guest network issue?
Nov 28, 2023Guru - Experienced User
IF you didn't update the RBS, lets get that online. Hopefully it will connect so you can update the RBS.
