SporadicWifi
Nov 28, 2023Tutor
I am having the worst disconnection problems imaginable
How were you able to get the new Firmware? I am having the worst disconnection problems imaginable.
SporadicWifi
Dec 04, 2023Tutor
I was able to get the FW last week through support. I've only had one instance of iPhone 15 Pro Max disconnecting and not able to connect without a reboot. Support has had be reset network settings on the iPhone and will continue to monitor. Thanks for the help and following up.
Dec 04, 2023Guru - Experienced User
Is Private IP address disabled on the phone? Just checking this.
- SporadicWifiDec 04, 2023Tutor
Private Wi-Fi Address and Limit IP Address Tracking are both turned off. iCloud Private Relay is also turned off, although I'm not sure if this one matters.
- FURRYe38Dec 04, 2023Guru - Experienced User
Ok. I only disable PWA on my 12 pro max.
