SporadicWifi
Nov 28, 2023Tutor
I am having the worst disconnection problems imaginable
How were you able to get the new Firmware? I am having the worst disconnection problems imaginable.
Straq
Dec 05, 2023NETGEAR Expert
Hi There,
Engineering Team here. If one satellite is in issue state, more than likely it was causing your clients to get disconnected due to this bad satellite. Can please factory reset the satellites just to make sure they are in a good state.
Please let us know right away if you encounter issues again
- SporadicWifiDec 06, 2023Tutor
Both Satellite's factory reset. Still having disconnection problems with iPhone 15 Pro Max. Did a reset of network settings on iPhones and will monitor.
- SporadicWifiDec 11, 2023Tutor
This happens to both my iPhone 15 Pro's as well...
- StraqDec 12, 2023NETGEAR Expert
Update: There are some flaws in the seamless roaming around the network. We are working to improve this in the upcoming firmware. Will update again once a firmware is ready
Will also like to bring up that latest iOS 17 production firmware has some Wi-Fi issues as well. I am currently running Beta firmware iOS issue looks to be improved and better but still see some lag between connections of router and satellite
