pierreha
Dec 27, 2023Aspirant
I have iPhone 15MP running 17.2.1 and orbi 970 running 9.10.2.3
I m facing the same issue, I have 15MP running 17.2.1 and orbi 970 running 9.10.2.3 and my phone keep dropping wifi all the time, any fix
thank you
Dec 27, 2023Guru - Experienced User
Please update your systems FW:
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
FYI:
pierreha
Dec 28, 2023Aspirant
I followed you tips, I updated to latest orbi firmware yesterday, I disabled all iPhone settings requested and still I m getting kicked off the wifi.
I have 3200sft house, I have 1 RBR and 2 RBS and they are far away from each other, even I shutdown the RBS, I m still facing the same issue. All RBS are wireless.
I have 2.4Ghz channel 11 and 5GHz channel 48. Even if I m connected to Guest wifi, it is happening the same.
Thank you
- FURRYe38Dec 28, 2023Guru - Experienced User
Has the system been powered OFF for 1 minute then back ON after the FW was applied?
- pierrehaDec 29, 2023Aspirant
I did that yesterday evening and still today I keep getting disconnected
should I enable Enable 20/40 MHz Coexistence?
or
Enable 240MHz Bandwidth?
thank you for your help
- FURRYe38Dec 29, 2023Guru - Experienced User
20/40Mhz should be enabled by default. However try enabling it it's not already enabled or if it is enabled, disable it and test.
Can enable 240Mhz however this would be only for the wireless back haul support.
