sgarr
Dec 05, 2023Star
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970. When I first got it every time the pixel would connect to the router, the router would immediately reboot. They gave me beta f...
Straq
Dec 12, 2023NETGEAR Expert
Update: We have fix the connection fail issue. However, we have not fixed the no internet issue being seen on Pixel 8 yet. Please rest assure we are trying our best to resolve this as soon as possible
sgarr
Dec 24, 2023Star
I have firmware version V9.10.3.1_1.1.16. Every time I go downstairs the signal should hand off to the router and my phone will just say my network has no internet access with an exclamation mark and I have to reconnect. Are there any firmware updates I should try?
- FURRYe38Dec 24, 2023Guru - Experienced User
Have you seen this pop up on your Orbi app?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?- sgarrDec 24, 2023Star
I'm not sure what you are asking about if something has popped up on the orbi app. I have 3 satellites and 1 router. I have great signal strength and in the admin the signal shows as good. My issue is when you move from one location to the other even with full signal strength the router will kick my phone off the network and I have to manually reconnect. The 960 system worked perfectly. I am probably10 feet from one satellite and the router and the satellite are probably 30-40 feet apart. My pixel 8 pro disconnects from the router when it tries to connect, possibly to the satellites as well. The router no longer reboots when this happens with the new firmware however it just kicks the phone's wifi off and I have to manually reconnect. I am typing on my laptop which stays pretty much in the same location and there aren't any issues. The only wifi 7 device I have is the pixel 8 pro. My brother's pixel 7 pro also keeps getting kicked off the network as well. The 2.4ghz channel is auto and the 5ghz channel is 40. I may need to try returning the router and exchanging it to see if that will help anything.
Sorry for got to paste the link:
Please give feedback to the question presented.
