sgarr
Dec 05, 2023Star
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970. When I first got it every time the pixel would connect to the router, the router would immediately reboot. They gave me beta f...
sgarr
Jun 05, 2024Star
Unfortunately this firmware update did not fix the issue. I am having the same issue with samsung 24 ultra. I changed phones from the pixel 8 pro to samsung thinking this would help. I still have a pixel 8 pro I can test so will see if it changed anything in the next few days. I have 4 satellites. When I walk upstairs with full signal wifi calls will drop or if I walk outside. I will have to manually disconnect from my wifi network and reconnect to resolve the issue but only if I don't walk to other rooms. However this issue is not as pronounced on the IoT network. Anyway I hope a solution will come some day.
Jun 06, 2024Guru - Experienced User
Does this happen with turning off all but one RBS?
Still happens if you disable the IoT and Guest Network?
What channel configurations are currently set on the router?
What is the distance between the router 📡 and satellite(s)🛰️?
