sgarr
Dec 05, 2023Star
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970. When I first got it every time the pixel would connect to the router, the router would immediately reboot. They gave me beta f...
sgarr
Dec 25, 2023Star
So I woke up this morning, pages were loading slow on my pixel 8 pro with the orbi 970, and I'm getting like ~400kbps download on a speedtest. I disconnected from WiFi and reconnected to the WiFi network and then back to 1gbps. What is the issue with the 970 system? I may try one more firmware update if it doesn't fix it I will have to send these back.
cmftblynu
Aug 17, 2024Star
The only way we got ours to connect, was to use the IOT ssid, and dedicate that one just to the google pixel, and it seems to connect ok to that one only...
