jjp22
Mar 11, 2026Tutor
I'm at wits end with 870
Before Christmas I upgraded my internet to 2GIG, and purchased an Orbi 870 with two satellites to handle it. It seemed OK at the time. Then the second satellite started connecting only to the first...
Mar 11, 2026Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Too Much Wifi: https://youtu.be/UR0viMLISz4
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
