jjp22
Mar 11, 2026Tutor
I'm at wits end with 870
Before Christmas I upgraded my internet to 2GIG, and purchased an Orbi 870 with two satellites to handle it. It seemed OK at the time. Then the second satellite started connecting only to the first...
jjp22
Mar 13, 2026Tutor
Let me ask this - is it normal if I have two satellites in locations and don't move them, and "fixed" wifi devices like Nest thermostats, a printer, and a leak detector, for the devices to switch back and forth between satellite they are connected to?
Mar 13, 2026Guru - Experienced User
Thats called ping ponging if the devices can't pick between on RBS signal or the other RBS signal.
Mostly means that there maybe too much wifi signal over lap or signal saturation and the devices can't keep locked on to one signal.
Saw this years ago with my NEST controllers and Orbi AX system.
