JesseDiaz
Jan 13, 2024Guide
Im having issues with rebooting as well
Im having issues with rebooting as well. When I first purchased this in December 2023, the router was rebooting every hour. I reached out to the community here and got some help from a Senior Wirel...
JesseDiaz
Jan 28, 2024Guide
No progress. Netgear is still working on it. Last I heard 3 days ago was that they were still waiting on the engineering teams response.
But i did see that there is a new firmware out.....
New - RBE970 / RBE971 Firmware Version 9.11.0.1 Re... - NETGEAR Communities
Haven't tried it as its not showing up on my router so I may have to manually update it.......
Jan 28, 2024Guru - Experienced User
Yes, manual update is recommended:
- JesseDiazJan 28, 2024Guide
Im going to give it a try tomorrow. But is this supposed to resolve the router rebooting?
- FURRYe38Jan 29, 2024Guru - Experienced User
Yes. Let us know after 3 days or sooner if it doesn't.
I recommend a full power OFF of the RBR and RBS units for 1 minute then back ON after the FW has been applied.
- JesseDiazJan 31, 2024Guide
Well I had high hopes but my router randomly rebooted. I followed the manual update instruction exactly including the order to update and turning off everything including the modem and turning everything back on in the order recommended.
