jcf73
Nov 07, 2023Follower
I'm seeing frequent disconnects while the router is 'optimizing'
I have a PC connected via ethernet to one of my Orbi satellites. I'm having frequent disconnects once or twice per day. When I check the app, the satellite shows disconnected. The LED on the satellit...
Nov 07, 2023Guru - Experienced User
What FW version is loaded?
Does this also appear on the RBRs web page?
What version of Orbi app are you using and what platform? Apple or Anderoid?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)?
What channel configurations are currently set on the router?
Is the 240Mhz feature enabled on the RBR under Advanced Tab/Advanced Settings/Wireless Settings
