jcf73
Nov 07, 2023Follower
I'm seeing frequent disconnects while the router is 'optimizing'
I have a PC connected via ethernet to one of my Orbi satellites. I'm having frequent disconnects once or twice per day. When I check the app, the satellite shows disconnected. The LED on the satellit...
Nov 07, 2023Guru - Experienced User
Need you to enable debug logging on the RBR under router IP address/debug.htm
Enable WAN/LAN capture as well. Observe the RBR event then save off the logs.
PM me or Straq with the link to the saved logs put up on some cloud service like onedrive or dropbox.
jcf73 wrote:
I have a PC connected via ethernet to one of my Orbi satellites. I'm having frequent disconnects once or twice per day. When I check the app, the satellite shows disconnected. The LED on the satellite is flashing white or solid magenta. A few minutes later, it will reconnect. Why is it doing this?
