jtmtech
Apr 13, 2026Aspirant
Inconsistent connectivity on LAN
I have inconsistent behavior when trying to ping or ssh across devices that are all on the same WLAN. Is this a known behavior? I have an 871 router and 4x 870 satellites running firmware V10.5.20.4_...
CrimpOn
Apr 13, 2026Guru - Experienced User
jtmtech wrote:inconsistent behavior
Please clarify "inconsistent"
- Network connections between the Mac client and some WiFi devices work, but others fail?
or - Network connection to the same device sometimes work correctly and sometimes fail?
