Kappo_84
Apr 01, 2024Apprentice
Intermittent connectivity/latency spikes/disconnects
Recently upgraded to a new mesh - orbi 972 - to replace an “aging” 850 series. I was excited to pump enhanced 6E around the home as well as the (on paper) stronger wireless backhaul setup. Sadly my ex...
Apr 01, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What devices are you connecting to the system?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Is the RBS showing 5+6Ghz in the RBRs web page under Connected Devices?
Armor, Smart Parental Controls or Traffic Meter.
Kappo_84
Thanks, answered pretty much all of the info in the initial post. To confirm/add:
- ISP is virgin media in the UK, using a super hub 5.
- router/satellite are ~30ft apart but have experimented and no change.
- not experienced any issues wired.
No other changes with devices which were all working perfectly fine on the 850 system.
I’ve tried disabling armour (as it’s useless anyway) to see if that helps.
- FURRYe38Apr 01, 2024Guru - Experienced User
Is the modem you have in modem mode or router mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopDoes this happen with the RBS turned OFF?
What channel configurations are currently set on the router?What devices are you connecting to the system?
- Kappo_84Apr 01, 2024ApprenticeThanks - yes ISP router is in modem mode, as it was with previous set up. No double NAT, no conflicting WiFi etc.
Satellite is showing 5+6 ghz connection with “good” displayed on the device page.
No MAC randomizers enabled. Devices used are a huge mixture - iPhones/ipads/macs/tvs/peloton/ps5/laptops etc. No issues previously.
Channel configurations all left on default except 5ghz which is on 48 (vs default 40). Can set this back to test if helpful.
Will try and test with satellite off - hard with some areas as WiFi doesn’t cover whole house (eg home office).- FURRYe38Apr 01, 2024Guru - Experienced User
Can you see if any Wi-Fi neighbors are near by your home and if there using same channels as the Orbi system is?
If channel 40 isn't being used or maybe one or two others that are far away distance wise, try channel 40.
