Kappo_84
Apr 01, 2024Apprentice
Intermittent connectivity/latency spikes/disconnects
Recently upgraded to a new mesh - orbi 972 - to replace an “aging” 850 series. I was excited to pump enhanced 6E around the home as well as the (on paper) stronger wireless backhaul setup. Sadly my ex...
Kappo_84
Thanks, answered pretty much all of the info in the initial post. To confirm/add:
- ISP is virgin media in the UK, using a super hub 5.
- router/satellite are ~30ft apart but have experimented and no change.
- not experienced any issues wired.
No other changes with devices which were all working perfectly fine on the 850 system.
I’ve tried disabling armour (as it’s useless anyway) to see if that helps.
Apr 01, 2024Guru - Experienced User
Is the modem you have in modem mode or router mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
What devices are you connecting to the system?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
Is the RBS showing 5+6Ghz in the RBRs web page under Connected Devices?
