Kappo_84
Apr 01, 2024Apprentice
Intermittent connectivity/latency spikes/disconnects
Recently upgraded to a new mesh - orbi 972 - to replace an “aging” 850 series. I was excited to pump enhanced 6E around the home as well as the (on paper) stronger wireless backhaul setup. Sadly my ex...
Kappo_84
Feb 21, 2025Apprentice
I've not found any solution as of yet - doing a full reset will not fix the issue (I've done that multiple times). This has been present on all fw versions and the beta versions they've given me. I've provided logs after logs and gone through so many steps. There is clearly some process or sync event that's happening that causes this.
As you've highlighted - it's a short spike of 500-1000ms for a second or two and then it's back to normal.
I've had older orbi mesh systems oevr the years and none of them have ever exhibited this. Please raise a support ticket with Netgear to highlight this issue as I feel they are just assuming it's some random set up issue I have, but it's evidently not.
My case number if you want to reference is 48580405.
MiniTuna
Feb 23, 2025Guide
One follow up question. I just read that the V10.5.16.3 firmware is in the wild starting to get pushed to batches of units but not yet on the support website. Have you been sent that one yet to try?
