piddyy
Feb 19, 2025Tutor
Interruption every hour
Recently, I have repeated interruptions on my WiFi devices. For example, I've noticed it on the Playstation Portal (streaming device via Wi-Fi), where I briefly lose the connection for about 30-60 se...
Feb 19, 2025Guru - Experienced User
If the Orbi is in AP mode, then it gets all it's services from the ISP side. If something fails there then would be coming from the ISP side.
Does the front LED on the RBR or RBS turn PINK or WHITE when this happens?
How is the RBR configured for AP mode? Dynamic or static IP address configuration?
How is the RBR connected to the ISP Router? Yellow WAN port right?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
