zaguama
Dec 03, 2023Aspirant
IoT SSID Broadcast
Hi, is there any way to disable the IoT SSID broadcast on this mesh wifi 7 system? I have it unchecked and it doesn't allow me to connect which is the expected behavior but why would it broadcast the ...
- Dec 03, 2023
Where are you disabling it? On the RBR web page?
What browser are you using?
Mines disabled with using MS Edge.
Try enabled it, then disabling it. After you apply the change, powrer OFF all RBS and then the RBR for 30 second, then back ON with the RBR first, check to see if the IoT network SSID is present, if not, power ON the RBS. Wait for ready. Check for IoT SSID again.
Dec 03, 2023Guru - Experienced User
