Jtcooper87
Feb 06, 2024Tutor
IPv6 setup help RBE972s
I just bought the RBE972s and I am having issues setting up IPv6. My service provider is Kinetic by Windtream. I know for a fact that they have IPv6 because it works with the rented router that they p...
Jtcooper87
Feb 07, 2024Tutor
1.So the RBE972s is running the latest firmware available: 9.10.4.1_1.1.17.
2.I am not using the Orbi as a bridge currently. The Orbi is connected directly into the wall port using the supplied cable that came with the RBE972S.
3.I was able to have Ipv6 at my house next door using a Netgear Nighthawk AX6 router (no modem/same ISP).
Feb 07, 2024Guru - Experienced User
What is not working specifically with IPv6?
Have you been to https://ipv6-test.com to check the state of the protocol?
