Jtcooper87
Feb 06, 2024Tutor
IPv6 setup help RBE972s
I just bought the RBE972s and I am having issues setting up IPv6. My service provider is Kinetic by Windtream. I know for a fact that they have IPv6 because it works with the rented router that they p...
Jtcooper87
Feb 07, 2024Tutor
1. -My Xbox Series X does not recognize the connection as IPv6 at all where it did before switching routers.
-Given that my ISP, provides native IPv6 (at least I was told by my ISP), I would prefer not using the 6to4 Tunnel, since it is a dumbed down version of IPv6.
2.I went to a similar site, but I have attached the results from the above mentioned website.
Feb 07, 2024Guru - Experienced User
And if you disable IPv6 on the RBR does xbox work normally?
