gvlierop
Jun 25, 2024Aspirant
Is it possible to add an extra Wireless Access Point to a Oribi 970 system (not a 970 satellite) ?
I Have an Orbi 970 set up but there is still one point outside on the end of the garden where there is a bad wifi signal for my Ring Camera. This is because the Wifi Cam sits behind the brick wall o...
- Jun 26, 2024
Yes and would need to set up a different wifi SSID name and use far apart different channels.
Jun 27, 2024Guru - Experienced User
Metal and brick do a great job of blocking wifi.
You can use a different extender but you'll still have to try to find an angle that works on the camera that helps reduce/remove those obstructions.
