gvlierop
Jun 14, 2024Aspirant
Is it safe to update manually RBE970 / RBE971 Firmware Version 9.12.3.3
On automatic update mode, my Orbi 971 doesn't find a firmware update but there is a newer version available on the site:RBE970 / RBE971 Firmware Version 9.12.3.3 Is it safe to update the system m...
- Jun 15, 2024
Recommend a power cycle of the system OFF then back ON. Give about 10 minutes and enjoy. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
CrimpOn
Jun 14, 2024Guru - Experienced User
This firmware was released June 3, 2024. See the release notes:
https://kb.netgear.com/000066213/RBE970-RBE971-Firmware-Version-9-12-3-3
Safe? Solves issues? Too early to tell (in my opinion)
- gvlieropJun 14, 2024Aspirant
Thx for your quick reply.
Do you know why the update doesn't show up in the automatic update mode?
Maybe it is not compatible in the Netherlands?- gvlieropJun 15, 2024Aspirant
Updsate:
Well, I just upgraded the firmware (manually) on the 970 and 971 units. No problem so far.- FURRYe38Jun 15, 2024Guru - Experienced User
