gvlierop
Jun 14, 2024Aspirant
Is it safe to update manually RBE970 / RBE971 Firmware Version 9.12.3.3
On automatic update mode, my Orbi 971 doesn't find a firmware update but there is a newer version available on the site:RBE970 / RBE971 Firmware Version 9.12.3.3 Is it safe to update the system m...
- Jun 15, 2024
Recommend a power cycle of the system OFF then back ON. Give about 10 minutes and enjoy. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
gvlierop
Jun 15, 2024Aspirant
Updsate:
Well, I just upgraded the firmware (manually) on the 970 and 971 units. No problem so far.
Jun 15, 2024Guru - Experienced User
