TOPS119
Nov 08, 2025Luminary
Is the new firmware working or not
I had issues downloading the new firmware 9.13.2.1 for the RBE 970 has a question sign on the file after download did they release a fix for this or is it the same old version being circulated with the error ?
I did the update on the main Router which is the 791 and the other satellites auto updated. Thats different and new .
- TOPS119Luminary
Ya believe NG did some tuning in to make sure RBS are updated as well, even if the RBR is updated first, the RBS should follow up as well.
- avalynnAspirant
It looks like there was an issue with the Netgear firmware 9.13.2.1 for the Orbi RBE 970/971 series: the download package contained the old version instead of the proper updated firmware
All that was corrected and FW packages with in the .zip file are correct now:
New - RBE970 / RBE971 Firmware Version 9.13.2.1 Released | NETGEAR Communities
- TOPS119Luminary
Did you do the update ? as I just tried and get error same way with thee files
You can always manually update. Its usually the process I recommend anyway as I'm not trusting of the auto-update and the app update method. I've seen to many issues/corruption posts from users using those methods.
