Dazza762
Nov 15, 2025Luminary
Issue with various apps on android devices
Since upgrading to the 870 mesh system various apps on my wife's android phone aren't loading. Everything is fine on iOS devices but apps such and the BBC News app are failing to load on the android ...
Nov 15, 2025Guru - Experienced User
Dazza762 wrote:I really don't understand what's causing this as it seems to only affect android devices
Just to clarify this -
- These apps all load when the phone is not connected to the 870 wifi, but all fail to load when connected?
- Are there any apps that work correctly? Email, Chrome, etc?
- Dazza762Nov 15, 2025Luminary
- Yes, all apps load fine when not connected to the Orbi wifi
- Yes, some apps seem ok and the problem with certain apps is intermittent, they will work sometimes when connected to the Orbi but will fail to load at other times.
- StephenBNov 15, 2025Guru - Experienced User
Yes, some apps seem ok and the problem with certain apps is intermittent, they will work sometimes when connected to the Orbi but will fail to load at other times.Do you use mac address admission control? Or have Armor or parental controls turned on?
Not sure what Mac address admission control is but I don't have Armour and there are no parental controls turned on.
