Dazza762
Nov 15, 2025Luminary
Issue with various apps on android devices
Since upgrading to the 870 mesh system various apps on my wife's android phone aren't loading. Everything is fine on iOS devices but apps such and the BBC News app are failing to load on the android ...
Nov 15, 2025Guru - Experienced User
What modem/gateway is the router connected to?
are you using IPv6? or is it disabled?
Did you try StephenB DNS recommendation? If you do and you have IPv6 enabled, make sure that you change the IPv6 DNS servers as well. (or just disable IPv6, we've seen tons of issues with some ISP's)
