JoeJoeJoeJoe
Apr 12, 2025Tutor
Issues getting Windows 11 laptop to connect to Orbi 870
I have HP Windows 11 laptop that uses a Qualcomm FastConnect 6900 WiFi 6E adapter. The WiFi worked fine with my previous Orbi Pro SXR80, but after upgrading to Orbi 872 system, won't connect. ...
JoeJoeJoeJoe
Apr 13, 2025Tutor
I checked twice, no access restrictions are set on the Orbi
I when thru and reviewed all the Windows driver settings for the Qualcomm WiFi chip.
- Set the preferred band as 5GHz (didn't make any difference if I left auto or set to 5GHz)
- Has a parameter for setting the WiFi standard - e.g 802.11b, n, ax, etc... The default is upto ax, so doesn't have an option for WiFi 7, which would be 802.11be. Maybe this is causing the issue? However I did try to connect to the Orbi IoT network that only has 2.4GHz enabled and all my IoT devices connect to this network and they were mfg. well before WiFi 7 was around. Windows Laptop won't connect to IoT network.
The laptop does see the network / SSID since is listed as available network, just doesn't connect (WPA2 or 3 process to authenticate).
Apr 13, 2025Guru - Experienced User
I'd make contact with the mfr of the laptop or chipset mfr and ask about this. Sounds like something with the wifi or wifi drivers is not compatible between Orbi and Qualcomm. I don't think is this the first time we've seen this.
Check to see if the adapter in the laptop can be changed out or upgraded for something Intel. I know Intel based adapters work well with Orbi systems.
