Crasje
Jul 03, 2025Tutor
Logging in on the Orbi 870 web interface interaction issues
Hello, When I want to log in to the Orbi web interface via my ethernet wired desktop. I have some strange behavior. When I go to the URL and on the log in page immediately type username - cl...
Jul 03, 2025Guru - Experienced User
What browser are you using?
Happens with other browsers?
Be sure to disable any browser add ons.
Happens with a different PC?
MS Edge, Safari, Firefox or Opera have all warked for me on Orbi BE systems.
Crasje
Jul 03, 2025Tutor
The freezing of the webinterface happens in Chrome and Edge on my W11 desktop.
When I use my MacBook pro, Chrome gives an error: "Orbilogin's server IP adres could not be found" when I try to connect to http:/orbilogin/
And Safari logs in fine with the above address
- FURRYe38Jul 03, 2025Guru - Experienced User
Try using 192.168.1.1 in a web browser?
- CrasjeJul 03, 2025Tutor
192.168.1.1 doesn't work on any system or any browser
Firmware is V10.5.19.4_1.27
It should if thats the current IP address of the RBR, unless it's been changed.
How was the FW loaded on the system? Auto Update or manually?
