Crasje
Jul 03, 2025Tutor
Logging in on the Orbi 870 web interface interaction issues
Hello, When I want to log in to the Orbi web interface via my ethernet wired desktop. I have some strange behavior. When I go to the URL and on the log in page immediately type username - cl...
Crasje
Jul 03, 2025Tutor
The freezing of the webinterface happens in Chrome and Edge on my W11 desktop.
When I use my MacBook pro, Chrome gives an error: "Orbilogin's server IP adres could not be found" when I try to connect to http:/orbilogin/
And Safari logs in fine with the above address
Jul 03, 2025Guru - Experienced User
Try using 192.168.1.1 in a web browser?
- CrasjeJul 03, 2025Tutor
192.168.1.1 doesn't work on any system or any browser
Firmware is V10.5.19.4_1.27
- FURRYe38Jul 03, 2025Guru - Experienced User
It should if thats the current IP address of the RBR, unless it's been changed.
How was the FW loaded on the system? Auto Update or manually?
I use my Orbi router as an access point, so it is probably a different IP address provided my the router of my internet suppliers. Let me see if I can remember how to connect with that one...
