Jdawg2467
Mar 04, 2025Tutor
Major Latency Spike Every Hour at the Same Exact Minute of Every Hour
Every hour my netgear orbi satelite gets a major lag spike of about 50-100ms at the same exact time consisting of 3 spikes and while gaming online these lags last for about 20-30 seconds of actual ti...
Jdawg2467
Mar 04, 2025Tutor
Ya I disabled the wifi on the AT&T modem and put it in pass-through mode and assigned a lease for the netgear orbi router or whatever you had to do.
It's probably around 30-40 ft max between the router and satellite and the satelite is 1 floor down from router. Like I said it says excellent when I look at satelite connection on orbi router login web page.
I know the best ideal situation would be to wire ethernet directly to the router but it's just not possible right now and that still wouldn't solve the issue of the satellite lagging every hour but it does solve the ps5 lagging while gaming issue cause I ran an ethernet through my entire house connected to router and it didn't do it.
Mar 04, 2025Guru - Experienced User
Ok, I'm going to put my 770 series back online and help check this. I normally game from the RBR always. I just had my 770 series online for past month and was going pretty good. Seems to be others as well seeing this and NG is aware of it.
