ShannonC
Jul 11, 2024Tutor
Mixing old and new Orbi routers?
I have a RBE971(Router) and RBE970 (Sat) in place and working (which does not show up in the "Associated Products field above). I am having range issues where it does not cover my front yard. I run a...
Jul 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
