TOPS119
Jun 06, 2024Luminary
Modem placed in Bridge No internet is now coming from it
As title states I place the modem in Bridge mode and automatically loose internet, What am I doing wrong is there something else needed to be done when switch a modem into bridge mode? Took it out of...
CrimpOn
Jun 06, 2024Guru - Experienced User
It is helpful to know
- The specific model number of this modem
- Which Netgear product is connected to this modem
- What 'mode' the Netgear product is in ('router'? 'access point.?)
TOPS119
This is a
Modem - SERCOMM- FG110DR
ROUTET -OEBI WIFI 7 971
THE ROUTER IS IN---ROUTER MODE
- FURRYe38Jun 07, 2024Guru - Experienced User
Possible built in router and wifi on your modem?
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
TOPS119 wrote:
This is a
