booclay
Apr 05, 2024Tutor
Modem that works well with Orbi 970 (UK)
Hi All, I've just recently purchased the Orbi 970 mesh system. One thing I didn't realise, is that it doesn't have a modem in it. The problem I have is that I have a BT smart hub 2, and that ...
Apr 05, 2024Guru - Experienced User
the smart hub should work fine. You just need to put in passthrough mode or enter the orbi's IP address into its DMZ.
booclay
Apr 05, 2024Tutor
Hi there and thank you for the response. I don't think you can do that with the BT smart hub:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-Hub-2-and-Bridge-Mode/td-p/2306834
Even if you could I really don't like the Smart Hub, its user interface is really poor.
Would you have a recommendation for a good modem?
Many thanks in advance
