booclay
Apr 05, 2024Tutor
Modem that works well with Orbi 970 (UK)
Hi All, I've just recently purchased the Orbi 970 mesh system. One thing I didn't realise, is that it doesn't have a modem in it. The problem I have is that I have a BT smart hub 2, and that ...
Apr 05, 2024Guru - Experienced User
booclay wrote:
World the DrayTek Vigor 167 be a good option for this?
I'm not in the UK/EU so I'm not great with their modems/options/setup. michaelkenward would be better at that.
do you have to rent your modem? Maybe the ISP would upgrade you to the hub 4
booclay
Apr 05, 2024Tutor
Ah cheers for the help even though you are not in the uk.
I think the smart hub and home hub are different as in i'm not sure the home hub 5 is an upgrade on the smart hub 2, but maybe they would swap them. I don't rent the hub.
