TOPS119
Jan 25, 2025Virtuoso
My orbi 970 Mesh satellite has two separate Macs and two separate ip
I have orbi wifi 7 970 3 pack which means I have two satellites and a router, I notice the satellites have two separate ip, meaning the ip address of both satellites are different, since its a mesh s...
- Jan 25, 2025
(Caveat: some Orbi features that have been around for YEARS have disappeared with the WiFi7 products. I do not have one and cannot check personally.)
On my old Orbi, the log can be found on the web interface, Advanced Tab:
My system allows me to email the log to myself every time it fills up (or at least it has up until the latest firmware version. (I should check) I hear that the WiFi7 Orbi dropped that feature.
Jan 25, 2025Guru - Experienced User
No.
the addresses have to be different as the IP address is per device. If they had the same, one of them wouldn't work.
TOPS119
Ok with that said back to the drawing board lol
- CrimpOnJan 25, 2025Guru - Experienced User
There are several very long conversations about the new 970 product and newer phones dropping the WiFi signal when moving between Orbi units. Scroll through the topics on this forum:
https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/bd-p/en-home-orbi-be
such as this one:
- TOPS119Jan 25, 2025Virtuoso
Yes im very aware as I had started most of them anyways this wasnt about the dropping this is about reading my log you have stated thats not the log that shows me the info I mention could you direct me to the log that shows the information that my orbi is not dropping signal/ uptime
