TOPS119
Jan 25, 2025Virtuoso
My orbi 970 Mesh satellite has two separate Macs and two separate ip
I have orbi wifi 7 970 3 pack which means I have two satellites and a router, I notice the satellites have two separate ip, meaning the ip address of both satellites are different, since its a mesh s...
- Jan 25, 2025
(Caveat: some Orbi features that have been around for YEARS have disappeared with the WiFi7 products. I do not have one and cannot check personally.)
On my old Orbi, the log can be found on the web interface, Advanced Tab:
My system allows me to email the log to myself every time it fills up (or at least it has up until the latest firmware version. (I should check) I hear that the WiFi7 Orbi dropped that feature.
TOPS119
Yes im very aware as I had started most of them anyways this wasnt about the dropping this is about reading my log you have stated thats not the log that shows me the info I mention could you direct me to the log that shows the information that my orbi is not dropping signal/ uptime
CrimpOn
Jan 25, 2025Guru - Experienced User
