TOPS119
Jan 25, 2025Virtuoso
My orbi 970 Mesh satellite has two separate Macs and two separate ip
I have orbi wifi 7 970 3 pack which means I have two satellites and a router, I notice the satellites have two separate ip, meaning the ip address of both satellites are different, since its a mesh s...
- Jan 25, 2025
(Caveat: some Orbi features that have been around for YEARS have disappeared with the WiFi7 products. I do not have one and cannot check personally.)
On my old Orbi, the log can be found on the web interface, Advanced Tab:
My system allows me to email the log to myself every time it fills up (or at least it has up until the latest firmware version. (I should check) I hear that the WiFi7 Orbi dropped that feature.
Jan 25, 2025Guru - Experienced User
No.
the addresses have to be different as the IP address is per device. If they had the same, one of them wouldn't work.
TOPS119
Feb 01, 2025Virtuoso
Please take a look at both pictures as wireless shows connected orbi to be the same but wired is different
- FURRYe38Feb 02, 2025Guru - Experienced User
MAC AND IP addresses of each RBS should be different regardless of wireless or wire connected.
- TOPS119Feb 02, 2025Virtuoso
Well should be key words.. But you see the **bleep** happening in the picture right. So what you think is going on.
So what happens if you use the Generate new BH Password, hae the RBS first wirelessly sync to the RBR fully with front BLUE LED then after that connect one at a time to ethernet BH. Once at a time until you see the status change from Wireless to wired BH on the RBR web UI.
