RumRootsReggae
Sep 30, 2025Aspirant
Netgear Orbi 870 slow to stream from NVME SSD NAS
Hi Friends. I am a Netgear Orbi Newbie. I have just recently bought the 3 pack Orbi 870. I live in Perth, Australia. I upgraded from a much older system that did not allow me to stream 4K video from...
Oct 01, 2025Guru - Experienced User
Thanks for the pictures but your actual streaming setup is key.
- what are you using for streaming from the qnap? Like StephenB says, plex? Jellyfin? DLNA?
- what qnap is it (model)?
- Are you streaming wireless? Wired?
- What are you streaming to? fire tv? google tv? apple tv? (and the model)
- what actual speeds do you get?
- are you using software transcoding? hardware transcoding?
- What makes you think its a speed issue if the old system and orbi system both have issues.
I've had my home setup for media streaming for over a decade. I've moved from 480->1080->4k streaming. In my experience, the issue usually isn't the router. Its something with the setup you're using for it. Thats why details are key.
