Bobman63
May 02, 2024Guide
NETGEAR Orbi (Latest Gen) 970 Series Quad-Band WiFi 7 Mesh Network System
I hooked up my new NETGEAR Orbi (Latest Gen) 970 Series Quad-Band WiFi 7 Mesh Network System. When I installed the unit it updated the firmware automatically. My home is 7200 sq ft. I have the route...
- May 14, 2024
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 02, 2024Guru - Experienced User
You'll want to try different locations throughout the home. sometimes things in the walls (think hvac, foil lined insulation, etc) or applicances can block signal. so moving laterally/changing distance can help. I usually try several different setup locations to see how well it works. I'd also advise testing your speeds with a wired device on each satellite. Each wireless device might have different speeds and so a hardwired devices to the satellite will give you the most realistic speeds.
Any chance you have ethernet throughout the home? A hardwired backhaul really makes these devices sing.
- Bobman63May 02, 2024Guide
Hardwired one of the gets 1.1 gig the other gets 80 mbps plugged directly into the router with new cable I had an IT guy working on it, but no luck any ideas? You can see on the desktop running speedtest.net and fast.com flash 800+ mbps for an fraction of a second then immediately drop back top 80mbps. We are going to move some around today but I would think with wifi 7 inside the 7200 sq ft house that would be unnecessary. That was my hope. Most all in home is wireless except the 2 desktop computers. House is 30 years old so no current tech in the walls
Your thoughts
Bobby
- plemansMay 02, 2024Guru - Experienced User
All the satellites are hardwired into the router?
No they are not there are no wires to hook to. I did not think that I would need them with a 10,000 sq ft umbrella. With a $3000.00 + investment. I guess I didn't realize that satellites need hard wired as well. I thought that was the purpose of the satellite.
Bobby
